Date:    11-26-2017
Number of Hours:    3.40
Brief Description:    Right Wing cores
Fiddled with the rigs a bit, including a lead-in straight cut to reach the start poing.Made upper and lower cuts, producing RFC2/4. Still need to cut spar caps and separate the bit FWD of the spar.[Timewarp 13JAN18: Don't do it this way.]
Wire hung up one of the nails in the nose of the inboard template. Must angle the nails inward when an angle is involved from now on.
