Date:    9-9-2019
Number of Hours:    1.00
Brief Description:    Right Rudder cable/electrical conduit
Viki helped me invert the Fuselage, then I cleaned up some rough bits inside the left map pocket.
Marked up side for top of right armrest, matching the left. Marked up locations for right map pocket, electrical conduit clips and rudder cable conduit.
Enlarged electrical conduit hole in firewall with jigsaw, die grinder sanding cones and dremel sanding drums.
Installed electrical conduit clips, rudder cable conduit and rudder cable conduit conduit with urethane bond, clamped with cleco.
Using left side as a pattern, cut out right armrest top, vertical side bit and bevel bit that goes betwixt and assembled with urethane bond, clamped with drywall screws
