Date:    5-18-2019
Number of Hours:    2.00
Brief Description:    Electrical 'conduit'
Opened up left electrical conduit penetration through firewall with 1/2" drill die grinder and dremel 1/4" drum sander.
Marked up the position for the plans electrical conduit, and marked for placement of clips 6" apart.
Whilst I ponder the step of actually installing some of my babies note that I need to install the Rudder cable conduit above, and that it would make sense to coordinate the location of the tapes and conduit with the electrical clips. Rather than flox and taping as described in the plans I could use more clips!!! Rouse out the nylaflow and ponder.
Make a new male form from a bit of box taped 1/4" dowel stuck to a taped board, and two taped wood clampy bits. Layed up with 2 x BID, using some Norglass resin I got for non-structural stuff. I actually got it to make a new VHF antenna for airshows, and wanted West 105, but couldn't get it. Will try it out for finishing.
