Date:    8-29-2014
Number of Hours:    1.00
Brief Description:    Outer seat belt mounts / Rear heat duct
Removed peel ply, outer seat belt mounts look lovely. Note that the peel ply is much harder to SEE when trimmed close, almost forgot the bits in front of the IP. Possibly dangerous, but when removed the layups were lovely.
Cut out the foam for the rear heat duct. Rather than the plans paper pattern I cut my foam square on the bottom, and marked the profile with an offset pencil. The plans don't actually say, or give measurements, but I am proceding on the assumption the rear 45 degree bit is supposed to follow the line of the upper MLG Bulkhead. I actually used a bit of leftover glassed foam from the front heat duct for the baffle.
Primed angles. Had to redo the bottom, forgetting that it needs to be bare alodine for the flox bond. Took the opportunity to rough it up a bit.
