Date:    7-14-2015
Number of Hours:    0.30
Brief Description:    Assembling Elevator hardware
Torqued up CS-11. Worked well, hit 40 "lb with no obvious deformation and spare threads. [Timewarp 01AUG15: When fitting the Elevators to the Canard the CS-11 gets in the way of the hinges, delay fitting properly until after that]
Started sanding STBD MKNC-12A to fit spool piece.
No pictures.
