11-16-2017 |
3.30 |
Wing CS Spar outer layups |
Trimmed layup, cleaned up some blobs. Cut flox corners on ends that won't flow over from AFT face with Dremel. Prepped sites for LWA2/3 and floxed in place secured with trigger clamps, adding a block over LWA3. Pre-filled edges with excess flox. After a few hours break the flox was setting up nicely so finished floxing the edges of LWA2/3 and layed up 3 x UND strips over each hardpoint. Floxed up the ends, prepped foam and 1 x BID over the aft face of the hardpoints, overlapping onto the ends |
