11-15-2017 |
5.60 |
Wing CS Spar outer layups |
Filled/faired edges of access holes with flox. Prepped foam and taped edges with box tape. 2 x UND over FWD face @ 45 degrees, nice and wet. 0.6kg of MGS resin used, (gulp - plans say EZ Poxy is best, but I can't get it here). Peel ply. Prepped LWA 2/3 and cut UND strips for their reinforcement. After a break noted the layup was part set and tried knifetrim with a hobby knife. It would have been tricky because of the angle to do it when cured. Worked well, and I removed the tape. Hope I can get the peel ply off... Spent some time perusing the next chapter and making a shopping list. Traced templates for the wing jigs. |
