Date:    11-14-2017
Number of Hours:    1.00
Brief Description:    Wing CS Spar outer layups
Finished access holes. Actually cut out portion, taped the underside of a couple of penetrations of the BID, then covered with a bit of MDF hot glued from the inside. Inside of the spar looks cool, nowhere near as much micro drooling around as I was expecting.
Prepped foam and glass.
