11-7-2017 |
2.80 |
Wing CS Spar outer layups |
Trimmed layup, removed forms and bondo. Bit of masking tape stuck in the trough, will leave it there. Started sanding lumps with belt sander, router edge bit, random orbit sander, big sanding block. Started radiusing upper cap with router and sanding block. Bottom cap still a bit gummy. Routed out the holes for the shoulder harness blocks and micro'd in place |
