9-10-2017 |
2.20 |
Wing CS Spar |
Trimmed CS4 with Mr. Buzzy, on new cutting table with dust collector in itl Re-glassed 1 x BID in right tip of CS Spar internal, overlapping 1" onto previous. I laid the BID over the area, held at the top with nails in the CS2/3, and wet it out in place, and more thoroughly than last time. Worked brilliantly. Wish I had done it this way the first time. Smoothed the electrical cutouts in the internal bulkheads with 1/2" sanding drum in the dremel. Fixed CS4 on left tip and central with sloppy micro. I fear it will drip down on the inside. Weighted for cure. |
