8-28-2017 |
1.00 |
Wing CS Spar |
Cut up most of the BID & UNI for internal spar layup, using paper templates to cut up the tricky bits at the end. Marked up all bulkheads for future cable routing. I have read many cut them all out at this point, but after consideration it will work better to cut them after glassing. I also don't think I'll cut the ends until I've made the wings, in case positioning is NQR. |
