Date:    8-25-2017
Number of Hours:    0.80
Brief Description:    Wing CS Spar
Mounted CS spar cap templates on 3mm ply and rough cut on electric coping saw. A lot easier than 10mm MDF.
Pulled nails from foam, removed a couple of blobs on the joins with dremel.
Cut out and sanded shoulder harness blocks from 1" Hoop pine.
