Date:    8-21-2017
Number of Hours:    1.50
Brief Description:    Wing CS Spar foam
Some shop works. Burnt out my last incadescent bulb, (can't buy them in Australia any more), and fluro's don't run hot enough, and waste energy as light. Got some IR bulbs intended to keep reptiles warm and whacked it it. Had to change to an edison fitting. Epoxy cabinet now warming rapidly.
Trimmed remaining CS2/3 to height and sanded smooth.
After some difficulty figgered out "top" and "bottom" in Fig 1. (Fig. 9 shows the top is straight, so matches jig D, and the bottom has dihedral outboard, matching the free edge). Cut the Fig. 1 'mitres' using the router table, started to cut the transition.
