Date:    12-6-2019
Number of Hours:    2.50
Brief Description:    Elevator root fairings
Had decided some time ago to fit fairings to the fuselage inboard of the elevators, and to close up the gaps under the canard.
Fixed blocks of wing foam to the fuselage inboard of the elevators with urethane bond glue.
On cure, over a couple of days shaped it, taped over the elevators and canard and made a fillet from modelling clay between the lower surface of the canard and the fuselage.
2 x BID overall, overlapping onto taped canard and elevators. Peel plied edges.
