2-17-2016 |
0.60 |
Ballast Compartment |
Cut exterior glass and routed foam for Ballast Hatch window. Fitted hatch rubber seal and check fit. It all looks a bit tight. Not sure this is going to work. Nose bowl has cured with a bit of a warp, and doesn't fit cleanly on the nose either. Hmmmmm. Will evaluate. Beginning to think this pre-fab nose bowl is a bit of a WOFTAM. |
