12-31-2015 |
2.80 |
Nose gear doors |
Had difficulty managing the backing boards with the nose gear foot, so adjust the boards. Note nose strut cover is a bit proud aft, and sand back the SC tapes a bit to adjust. With the stut cover flush am surprised to discover the nose wheel interferes with the doors. Pop them off the boards and make a bump from 1/4" H100. Tape together the doors, with a multi-tool blade gap, and tape the gap with 1/4" masking tap. Install bump with micro and cover with 2 x BID with 1" overlap and peel ply. Cut remainder of hinges from MS20001-6. 2 x 3", 2 x 2". |
