Date:    10-28-2015
Number of Hours:    3.00
Brief Description:    Nose sides
Find a couple of websites showing those that install the sides, then have to cut holes in the result to achieve the required travel, some even after mounting them further inboard. Things still not adding up. Do some more measuring up and predictions, (which were all wrong, so not recorded here).
Fabricated a lower master cylinder mount and offered it up. Interferes at the bottom a bit, so the pivot point should be higher up. Taped rulers to the side of NG-30 in an attempt to measure travel, but too tired to actually do it.
