Date:    9-10-2015
Number of Hours:    1.20
Brief Description:    Preparing Canard locating pins
Re-arranged workshop and levelled Fuselage. I'm building in a one-car garage, so had to set the Fuselage across the shed.
Cut out the upper Longeron holes in the upper Firewall piece, fitted it to the Fuselage, clamped to the temporary Firewall, which hasn't been junked for something else, yet.
Drilled the upper Longeron doublers for the locating pins.
Cut the heads off two AN3-20A bolts and rounded the new tips.
Trouble fitting the pins, so eased the holes somewhat, made the STBD side hole too deep.
