10-17-2014 |
1.00 |
Cut fiberglass for nose-gear steering linkage. |
Tonight I cut the fiberglass to make a boot for the nose-gear steering linkage . I traced the full size pattern from the plans to use as a pattern. I also set the main gear leg supports into the fuselage just to check the fit. Looks real good. |
