4-11-2013 |
8.00 |
Updrill, deburr and rivet lower fuselage parts. |
Updrill, deburr and rivet lower fuselage parts. Time consuming to make certain everything fit right. I removed the lower fuselage parts to rivet the assemblies. Other builders had done the same and to be honest I could not figure any other way to access areas that needed to be drilled and riveted. The last thing a completed today was to remove the forward fuselage bottom skin and drill the cap seatbelt assembly. I still have some updrilling and riveting to do on C07. |
