1-30-2018 |
4.00 |
Build a cover around the elevator Push Pull tube. |
Today I built a cover around the elevator Push Pull tube in the baggage area. This is to prevent interferance with the tube if something came loose in the baggage area. I installed a removable inspection cover because the elevator tube has a joint at that location. |
