Date:    1-15-2012
Number of Hours:    2.00
Brief Description:    Made the fairlead blocks and drilled holes.
I was not happy with the fairlead blocks that I previously made so I did it again with much better results. The holes are drilled with the drill press.
I also bent a 3/4 in flange on the front edge of both aft side skins using the 30 inch brake.
