Date:    4-21-2017
Number of Hours:    2.50
Brief Description:    Back drill aft fuselage attach angles.
Today finished the drilling of the main spar blocks and angles. It appears to be perfect and certainly a big relief for me. I have been so screwed up about this drilling process, and reading all the other bulders comments that I felt I had to follow the croud. In the end I followed the Sonex plans exactly and it all worked out. the bolts are not as tight as I would like but if it is an issue I can have a couple of AN7 bolts turned down to make it a tighter fit.
