Date:    6-9-2011
Number of Hours:    2.25
Brief Description:    Inspection plate ring. Deburr top LE edge ribs.
Today I made a .025 ring to add strengh to the inspection hole if needed.. I have not deciced if I will install it yet but it seems that .025 skin and inspection plate is rather thin when you consider the number of times it will be off.for inspection. I am also installing nut plates on the inspection hole. It would seem easy to strip out the small sheet metal screws.
I spent 1.25 hrs deburring the forward ribs and looks like many more hours to follow.
