10-24-2010 |
5.25 |
Continue work on Aft Rib assemblies 1-5 |
I started out tonight building W16-09 Angle that is attached to Aft Rib 01Right. However I was distracted watching Green Bay Packers and Minnesota Vikings on Sunday night football and cut and attached the angle to rib #4 rather than 01 right. Note to self: No football while building airplane. I don't see that this error should be a problem. Rib 1 has a larger notch at the front rib flange. However, I will contact Sonex to get the OK or to order a new rib. I also pilot and updrilled the 10 rib assemblies 1 - 5. I built extra gussets to install on rib 5 that is not required. Next step will be to debur all of the gussets and ribs. |
