Date:    3-8-2018
Number of Hours:    1.00
Brief Description:    Install gascolator again.
I had previously removed the gascolator and considered coming straight from the fuel tank through the firewall and using steal reinforced fuel line. I have re-though it and will try the gascolator. I will use the flexible line to the firewall and then use aluminum to the gascolator. The flexible line should help prevent problems with the fuel tank fitting that a lot of builders are having.
