Date:    11-10-2017
Number of Hours:    4.00
Brief Description:    Test fit the fuel tank and straps.
During the test fit of the fuel tank and straps I found that the forward straps need to be shortened slightly. This was good to know because I would have been in the plane on my back under the tank to attach them after the glare shield is positioned. I would have been very unhappy to find out I put myself in that position and then had to crawl back out and remove everything to then shorten the strap.
I also cut a hole in the glare shield to fit a power port for some future unknown device. Just thought it would be nice to have one there.
I also installed the ground block from B and C. It has a matching ground block on both sides of the firewall.
