9-25-2019 |
2.00 |
Connect EGT & CHT probes. Route wires. |
Tonight we connected the CHT and EGT probes to the RDAC. Jeff worked on routing wires and cleaning up some electrical work. Jake found that the nut that holds the steering arm on the left rudder pedal is making contact with the fuel line. Reverseing the bolt should fix the problem. |
