Date:    8-7-2017
Number of Hours:    4.00
Brief Description:    Setting the main gear toe-in.
I made the angle and attached the phenolic block. the angle is now resting against the tool bushings and the ends of the axles. This is supposed to result in a correct .07 degrees toe-in. I ordered the double split collars that will secure the axle weldment to the gear legs. However they will not be here until Thursday.
