Date:    5-26-2017
Number of Hours:    3.75
Brief Description:    Install Steering boot and elevator trim cable.
Today I installed and riveted the steering control boot and elevator trim cable. The boot needed to be trimmed 2 inches and it seems to bind at the end causing drag on the rudder. Ill have to play around to get it right. Ran the trim cable from the control through the fuselage support gromments to the rear bulkhead to the elevator. again, I'll have to play around to get the right fit and control.
