Date:    1-11-2018
Number of Hours:    3.25
Brief Description:    Install intake manifolds.
The 30mm studs provided by Sonex for the heads to fasten the manifolds were a little to short to accommadte both the the spacer and the intake manifolds. I elected to use 40mm hex bolts instead. After cleaning the heads, spacers and intakes, I Used red Permatex RTV under the spacer and under the intake manifolds.
