Date:    9-12-2017
Number of Hours:    3.00
Brief Description:    Removed right cylinders, pistons, heads
Removed the right cylinders and the pistons. The cylinders and pistons don't look so bad. I'll need a independent set of eyes to verify the condition But I'm hopefull I can clean up the cylinders and install new piston rings. lots of oil to clean up. Also the $29.99 Harbor Frieght engine stand works great. I can rotate engine 360 degrees for the proper work position.
