7-29-2011 |
4.50 |
Wing LH Main Spar - remove scratches |
* Riveted W10-06L LH Tip Web Assembly. * Removed scratches in top and bottom spar caps caused by sharp points on cleco pliers before I ground them off. Used Scotch Brite blue discs in hand drill, plus SB pads. Won't make this mistake on the RH spar! |
