Date:    9-14-2018
Number of Hours:    1.00
Brief Description:    Riveted control brackets, riveted access panel, ri
I riveted the upper and lower elevator horns in place, along with the hinge bracket, and rear L-bracket. I riveted the acces panel onto the bottom skin for the electric trim actuator. I riveted the hinge pins on both sides of the elevator tip ribs.
