9-10-2018 |
1.00 |
Added rear elevator support, finished elevator ske |
I drilled and clecoed the rear elevator support between the two inner most rear ribs on the skeleton of the elevator. I then removed all components of the elevator and deburred/corrosion protected. then I reassembled and riveted the structure together, completing the construction of the elevator skeleton. |
