9-10-2018 |
1.00 |
Installed tip ribs, and added L-brackets to the el |
I positioned the tip rib bracekts in place on the main spar, and drilled/clecoed the tip ribs in place on the main spar. I then added L-brackets to the elevator rear support to be mounted in between the two inner most rear ribs. |
