Date:    8-27-2018
Number of Hours:    1.00
Brief Description:    Fabricated/Mounted rear mounting bracket
Using snips and multiple files, I cutout a curve on the rear mounting bracket used to mount the horizontal stabilizer onto the fuselage. I then laid out all rivet marks, and drilled the pilot holes on the bracket. Finally, I positioned the bracket in place, and mounted it to the rear spar with clecos.
