6-9-2014 |
4.00 |
Mgl iBOX and cables |
The MGL iBOX that is the main hub for the avionics now has its own place in the rear fuselage, from there some cables will be routed to the front and other data appliances. The radios wiring is also done, made the wires a bit longer than i probably need. the dsbu 25pin screw connector made the work allot easier. |
