11-20-2016 |
25.00 |
Flight and follow up. |
First flight of the Aircraft has happenned and at the time of writing 2018 i have flewn 26 hours. Video of first flight you can find here, https://youtu.be/PTojgcdBmio First flight ended quickly when i blew the alternator fuse, that resulted to change into a bigger battery 18aH. a few flights after that i had som ECU issues that made me land without engine power twice safely at the base. Ecu was replaced to Dual ECU in Belgium and now that works, after that i had a valve guide loosen, that was also fixed in Belgium. I see that as a part of testing a new aircraft, since then i have done 20 hours flight, Cruise speed is 74 knots, a few more knots wouldnt hurt. Thank you and good bye. |
