1-24-2014 |
6.00 |
Corners 2 |
So i skinned the whole fuselage, that took some time yes, so tedious when you needed to get the rivets in the corners soft flanges, loved it when you missed it and had to drill a rivet in the middle of the fuselage, bending :( And when finally done i discover that the reservoir hole is on the wrong side :crazy:, i was so sure i had it correct, well, late night builds:sleep: Ill just close that hole up and make a new one on the other side if its not possible to put it on this side? |
