Date:    8-18-2002
Number of Hours:    3.00
Brief Description:    Electric Trim Wire
Started routing the wire for the electric trim. drilled a hole in the bulhead to get the wire from the cabin/underseat area to the tail section of the airplane. Drilled and pop riveted cable tie brackets along the top stringer. Attached the wire to the first several brackets.
