10-12-2002 |
2.00 |
Static System |
Finished running the static lines forward to the Instrument panel. I used the 1/4" OD PP line from the Van's kit as it required smaller holes in the bulkheads. I used the 1/4" ID Tygon tubing from Cleaveland Tools between the two ports. I used a 1/4"X1/4"X3/16" tee connector to connect the lines together. |
