3-17-2013 |
1.50 |
Installed Aileron Hinges |
Installed both aileron hinges. Inboard hinge worked out great, but when I drilled the holes for the outer hinge, I noticed after I had already drilled that I hadn't clamped the hinge in place correctly. Ugh! Resulted in misaligned holes when I clamped the hinge in the correct location. So I decided to re-drill the holes (making them elongated) and installed a doubler to overcome the elongated hole problelm. See images 2 & 3. |
