1-17-2013 |
1.00 |
Mounted the Left Tank to wing |
It's starting to look like a wing. Had a litte trouble lining up the holes for the tank fasteners. Turns out I needed to just adjust the jack under the wing to get them to line up. I also noted some gap-osis between the skins of the outboard LE and the tank. Hmm... It's not terrible, but it just bugs me. The only I can think to do is add some more screws in between the ones alread in the joint. I'll think on that a bit. Is it worth it? |
