Date:    4-3-2009
Number of Hours:    6.40
Brief Description:    Attached sides to bottom; worked on bulkheads
Of these hours, 3.2 were Carole's.
Attached the right and left side to the bottom with clicos. Then worked on the three sides of the two bulkheads in the rear. The predrilled holes did not exactly match up on the three sides and the bottom so some redrilling will be necessary.
Getting these parts together is a big step in the fuselage construction.
