10-24-2006 |
3.50 |
Mock-Up Vertical Stabilizer & Rudder |
This evening, I prepared a mock-up of the vertical stabilizer and rudder assembly to see what it looks like so far. I loosely installed the rudder attachment bolts and then cut and test fitted the fiberglass tips on the ends (tape only for now; no match-drilling). The mock-up looks pretty good, and it is a little bigger than I expected. I am 6'-4" tall, so the photo below will give you some perspective on the size of the assembly. |
