Date:    9-25-2006
Number of Hours:    2.00
Brief Description:    Assemble & Rivet Skeleton
After the inside surface of the skin was primed, I re-assembled the skeleton and riveted the top and middle ribs between the front and rear spars. I left the bottom ribs clekoed together for now per the plans, since those pieces will be removed for temporary rivet bucking access later when installing the skin.
