5-7-2012 |
1.43 |
Countersinked and dimpled the counterbalance weigh |
So today I countersinked the counter balance weight and then dimpled the counterbalance rib. Then I bolted on the counterbalance weight to see how she fit together. Not bad, if I do say so myself. I then countersunk the trailing edge spacer. The also came out pretty good. All that is left is to prime the remainder of the skeletal structure and START riveting it together. |
