4-24-2012 |
2.75 |
Disassembled VS and prepped for priming |
Today I acid etched and scotch brited all ribs and spars and the inner skin of the HS. I also worked on my compressor as it had a small air leak at several of the fittings. I put some loctite sealent and that did the trick no more hissing sounds. Tonight I will leave it pressurized with the power switch off and if it hold pressure all night. The way it was it would be empty by morning. We'll see? No pic's today. |
