4-20-2012 |
3.85 |
Finished left HS rivet and started on Right |
Today I finished riveting the left HS skin on to the underlying skeletal structure with the exception of the rear spar and inboardmost ribs. I then riveted HS-707 onto the right skin and then clecoed the skin onto the front spar structure. I then riveted the end of the front spar onto the outboardmostg rib followed by riveting half the rivet on the skin. These are the ventral surface of the HS. I then called it a day. The parts are really starting to look like airplane stuff. This bad boy is cool!!!! |
